Lightning and Plumbing?
  • Lightning and Plumbing?
    Is there really a considerable danger being around plumbing in a thunderstorm?
    Example: Showering.
    What if all piping or the majority of it is non-metallic?
    Thanks.
    Re: Lightning and Plumbing?
    Example: Showering.
    Thanks.
    This is the main reason I don't shower and when I do it's only for a minute or less.
      Living like Ben Franklin, huh?
        lightning is a very powerful and unstoppable force. if the least resistant path back to earth is your shower and you, then yes, there is a risk. there's always a risk. people here may remember the strike i had on the well head. the pump was bad, the plasma tv was cooked, computer parts roasted, misc other electrical supplies were blown, the gfci receptacle was fried. other things that were powered on were ok. it's not consistent.
        look at it this way...if you're hit - you may be dead, you may turn into a savant or your winkie may stand permanently at attention and you will need to see a doctor
          Example: Showering.
          Thanks.
          Is the pipe filled with water. Water conducts pretty good I think.
          It's breakdown voltage is somewhere between zero and 1 volt.
            http://www.break.com/video/lightning...slow-mo-551149
              Years ago I was leaned over a tub cutting a copper pipe for tub spout when lightning struck outside. My hand got knocked off the tubing cutters so hard my shoulder hurt for a week. It can happen.
              David
                Impure water conducts. Generally, the more free ions it has the better it will conduct. That's why they use saltwater on the electric chair and not de-ionized water.
                  And since you will find little pure water out there (rainwater is probably the purest available from nature) in the world it should be considered conductive.
                    There is a chance especially if its metallic. This is one of the reason why I chose plastics.
                      I have no documentation but if:
                      - metal conducts, plastic doesnt
                      - there is no bonding of the water system
                      - impure water conducts
                      then you have a better chance of shock by lightning if there's no metallic pipe.
