to check or not to check?
  • to check or not to check?
    Okay folks I've got a question. Went to apt today complaint of not hot water. Noticed water heater was heating but also hooked into heating system. So I go in apt turn on heat and voila I've got hot water at faucets. So I have not dealt with these a lot so should I install check valve? where? at water heater? swing or spring? Thanks for any info
    Re: to check or not to check?
    In my area, hot water tanks can be used for space heating and potable water but not with one unit in the same system (not a single tank for both heat and potable). Also, lots of tanks are not designed for space heating, it'll say so on the rating sticker usually.
    Sounds like there is a cross-over someplace and the pump overrides the problem,
      No they are made to go this way you need to check for a priority switch, for hot water use versus heating
      JERRYMAC
      E-MAILJERRYMAC777@GMAIL.COM
      FIRE SPRINKLER CONTRACTOR,
      SINCE JAN. 1989
