Moen Cartridge core: Easy-Out or 1/2" Tap Method??
  • Moen Cartridge core: Easy-Out or 1/2" Tap Method??
    When trying to replace an ancient Moen 1200 brass/chrome cartridge and the guts come out only leaving you the core behind.... you prefer using a #6 easy out, or the 1/2" tap method?
    When using the 1/2" tap method, do you drop a dowel in the faucet body to push out the old moen core or just a stack of washers or socket placed against the head of the bolt?
    I do know they make a core puller that locks into place, but that's always a last option.
    Re: Moen Cartridge core: Easy-Out or 1/2" Tap Method??
    The moen tool is my first option and never fails. Get the one with the pin and little 3/8 compression sleeve.
    Rick.
      Rick.
      I have to buy one of these tools,any chance of a photo Rick,
      Thanks again
        They have them at the box stores in the moen alle
        Preview
        Jerry Mac
        MAC SALES 777
        SEWER EQUIPMENT SALES
        jerryhodge@att.net
          Thanks for that Jerry,
          I just haven't seen anything like that in Canada.
          Cheers all the same
            You should be pushing the Moen cartridge puller that you guys have behind the counter I saw one at the Westmont Xpress branch this morning!
            Using a tap or an easy out on a faucet would most definitely be my last resort. Like Rick, I always go to the Moen tool first. The key is to get the cartridge to rotate first BEFORE pulling!
            -Chris
              Thanks again
              i'm not sure if this is the tool rick was referring to: but here goes.
