I/2" steel 90 with 1/8" plug in threaded hole ?
  • I/2" steel 90 with 1/8" plug in threaded hole ?
    I see these before the gas valves on old boilers. What is the purpose for these please ? Always a plug in them ,nothing else?
    Re: I/2" steel 90 with 1/8" plug in threaded hole ?
    just a guess but to be able to do a pressure test?
      For reading the "gas" pressure on that line or burner
      JERRYMAC
      E-MAILJERRYMAC777@GMAIL.COM
      FIRE SPRINKLER CONTRACTOR,
      SINCE JAN. 1989
        Back in the day, when techs knew what a manometer was and how to use one, the 1/8" plug was for monitoring the gas pressure of that area of the pipe. It could have been for inlet pressure, manifold pressure, crossover pressure or there may have been more than one for measuring pressure drop which can be used to help determine volume/flow. You will note that gas valves typically have at least one of the same size ports, typically plugged with an Allen head plug that have many of the same functions.
        On propane systems there is a small pressure switch that can be inserted. It ties into the burner circuit and breaks the circuit at low pressure, usually less than 8" WC, to prevent sooting of the appliance.
          Not unlike the plugged taps on appliance regulators.
            This is on my own boiler. waiting for a new gas valve from pex supply. I bought a mannometer a few weeks ago, Now I can test My gas pressure. Thanks all for the info. PS,Pex supply has awesome prices !
