Water heater with NO boiler drain??
  • Water heater with NO boiler drain??
    Acquaintance says his water heater has no drain spigot.
    Is this a new kind of water heater?
    Self cleaning so no need for a drain?
    When replacing, how does one drain the 40 or 50 gallons of water from the tank?
    Remove a drain plug and channel the water into a floor drain?
    Thank you.
    Re: Water heater with NO boiler drain??
    I have to see a picture before I believe it.
      Maybe someone removed the plasic boiler drain and used a plug.
      A friend says: "I've seen the plastic valves get weak and blow of[f] the side of the tank!"
        Here's a rheem from circa 1980:
        AO Smith had a few. No recent 40 gallon+ residential models have no drain. BUT, some crappy mobile home versions dont have one. Some side tap units don't as you're supposed to install a drain on the lower side pipe. Some smaller electric models don't.
          Remove unit, tip over or drill hole. Usually when they fail they drain themselves.
            me 2
              I'd hate to tip a water heater weighing 330 or 420 lbs!
              (Discovered mother's water heater leaking hours before I was to fly to China.
              It had just started leaking - water was appearing from under the WH closet door.
              Turned off the water, drained it through a garden hose into the back yard, bought a new one at Home Depot and had it working before I had to leave for the airport.)
                Wow, I just learned something new ! What a PITA Those must be !
                  Seen one in a condo and thought that was strange. It did not last very many years. Sounds like it was made for a mobile home.
                  Learned latter that the builder was extremely cheap. Even skipped paying bills. Then left the state. But they caught up to him.
                  Roots beware of the C snake with shark teeth.
                    I would hesitate even in this instance buying a home depot water heater.
                      Working perfectly since October 14, 2003!
                        Your stock is high with MOM ,Bless Her
                          The tipping is the easy part. The moving is the hard part.
                            I don't believe it either. In over 26 years of doing this for a living I've never seen one without a drain. I doubt they exist. I've replaced every water heater made and have worked in three different states.
                              Many indirect water heaters have no drain
                              Fortunately they don't often fail... We still don't install ones we can't drain
