rusted toilet bolt
  • rusted toilet bolt
    The nut and the bolt are rusted together and the bolt is spinning. The sink cabinet is next to the toilet on one side and a wall is on the other side. A very tight area. I used a hack saw to remove. Is there any better, faster way to remove these without breaking the toilet?
    Roots beware of the C snake with shark teeth.
    Re: rusted toilet bolt
    When it spins, drive a wood wedge between toilet base N floor. right next to bolt. Now it wont spin, cut with sawsall. I have a few sawsalls, But I love the little millwakii Hacksall. Plenty balls N
    great for small jobs !
      Jobmax with metal cutting blade is great for this.
        I put a nut driver in a drill and turn the bolt. Slip a sawzall blade along the shaft and hold it so the rotation bites the teeth into the shaft.
          Along with the Hacksall, Milwaukee makes a number of cordless tools that run on the same
          12 volt battery. I find the multi-tool does a good job on cutting toilet bolts. Also the
          dremel-type rotary tool with a thin metal cut off wheel is okay, although it does throw off
          grit and dust.
            I like that Thanks Chief !
              Thanks for the ideals.
              Can't wait to try out.
                most of the rusted bolts i've seen are 1/4" steel bolt and steel nut. most have steel washers too. sometimes collapsing or grinding a slot in the washer will allow you to remove it. the nut will then usually pull right through the hole.
