Calif smart gas meters Page Title Module
  • Calif smart gas meters
    Is there any chance the new meters are delivering more gas pressure ? Has anyone checked ? We're in PG&E COUNTRY
    Re: Calif smart gas meters
    The meter might have less pressure drop, but its the regulator that controls pressure. Post a link wnd ill see if its a typical install.
    Rick.
      Kevin
      Next time you disconnect a meter, take a look inside. No springs or other means to control pressure. It's all about the regulator.
      Want to learn more, go to this site.
      Miners & Pisani | Welcome
      BTW: If you ever need a sub meter or regulator (for reduction of medium pressure), these people are the source in Northern CA
        Both My neighbor ,and Myself have flame sputtering after smart meter installs ! I recently purchased a Robinair Manifold Pressure test Kit. Havent used it yet. It comes with a tapered rubber port,at hose end. Does this insert into a plug hole on tee ? I believe I should have 7 " of water, right ? Thanks Kevin
          A digital manometer used during static and active pressures will tell the correct story.
          David
