Proper way to seal a toilet flange extender/spacer
  • Proper way to seal a toilet flange extender/spacer
    Should I use caulk to seal the spacer to metal flange or should I use wax? The flange is flush with the tile. Can I just use an extra thick wax ring?
    Re: Proper way to seal a toilet flange extender/spacer
    Thick ring should do it
      I was trained to bust out a cast flange and lead in a new one to proper height.As far as using a thick wax ring,they will eventually wash out.I use extenders for plastic flanges,seal them with silicone or putty and anchor them to the floor.Too many times I have seen where plumbers have screwed a flange to the subfloor then tile is installed and the flange is either flush with or below the finished floor,or a new floor has been installed and now the flange is too low.If I get called on a toilet seal and find this I always raise it.No callbacks,fix the problem.That's the goal.
        Plumbers Putty instead of wax rings.
          I agree with putty,except on a marble floor of course.I always get the argument only wax is approved,but bowl setting compound is allowed as well.I've pulled toilets that were set in putty for 80 years plus and never once leaked at the seal.Course you may have to bust the toilet to remove it.That's the way Grandpa did it.
            Pulled a toilet that was set in putty and the horn stayed in the flange.
            Approximately how much putty does it take to set a toilet. 1#, 2 #, 3#, 4#, 5#?
            You lay a big ring on and around the flange?
            Rick.
              I use slightly more than a wax ring.If you busted that horn off it must have been down a long time lol.I've done that,bust the rest off with a hammer and chisel..I get toilets that have benn in around darn near 100 years.Wall hung with a flush ell.Two closet bolts and two chrome wood screws holding them down.I've also had a couple that the horn was actually threaded in to a female threaded closet flange.Two chromed wood screws hold them in position.Those are real horns,not just a ridge to hold a wax ring in place.
                Nothing wrong with old school, per se. I'm an ol' timer myself.
                Putty used to be the way to go on those old 4-bolt, long horn WC's.
                But now it's just more practical, IMO, to use wax rings.
                With a closet flange that is flush with the floor I use a ring with a horn, on top of a regular ring.
                Flanges below the floor should be raised.
                The most important thing is not what you use for setting, but to properly secure the WC to the floor.
                Movement is the most common cause of seal failure.
                Unless the floor is perfectly level, shims will be needed.
                And the flange must be anchored to the floor.
                Caulk or grout seal the deal.
                  When I have to replace a rusted out flange(on PVC) I do this. I use putty. I clean the old flange first with PVC Cleaner or Mineral Spirist
                  Will Rogers Plumbing
                  Moore, Oklahoma
                  405) 323-2852
                  www.willrogersplumbing.com
                    Originally posted by Will Rogers Plumbing View Post
                    [ATTACH=CONFIG]18814[/ATTACH]
                    I see you use Knipex pliers. I use those too.
                      I also put a putty ring around the base of the water closet. After the bowl is secure, I trim the putty, then run a bead of caulk.
                        Will , Are those plastic hold down bolts in Your picture ?
                          I've known several guys who swear by the plastic toilet bolts.
                            I use 5/16 brass Johnny bolts.I ran across one toilet here with plastic bolts and one was broken...
                              Do they make reduced spacers for plumber 26 ??????
