In our converted home (two family to one) we have two water heaters. This morning, we woke up to find that there was no hot water in the first floor. In checking the respective water heater, for that floor, I saw its flames we're still burning. Could it be that this water heater has gone defective, anyway? Is it possible that there could be an issue with it, even though it's burner is firing?
Hot water problem.
Re: Hot water problem.
Originally posted by NLAlston View PostIn our converted home (two family to one) we have two water heaters. This morning, we woke up to find that there was no hot water in the first floor. In checking the respective water heater, for that floor, I saw its flames we're still burning. Could it be that this water heater has gone defective, anyway? Is it possible that there could be an issue with it, even though it's burner is firing?I can build anything You want , if you draw a picture of it , on the back of a big enough check .
Originally posted by Plumber Punky View PostNo water at all? Warm water? If the main burner is running then the problem lies elsewhere.
I wonder what the previous, temporary condition might have been due to.~Blessings~
Nathan
Does both the hot and cold connect to the top of the hot water heater if so the cold water has a tube that sends the water to the bottom of the tank if this is broken you will have much less hot water available. The cold will come in to the tank and then out the hot side without having a chance to heat up
Originally posted by PLUMBER JAY View PostDoes both the hot and cold connect to the top of the hot water heater if so the cold water has a tube that sends the water to the bottom of the tank if this is broken you will have much less hot water available. The cold will come in to the tank and then out the hot side without having a chance to heat upI can build anything You want , if you draw a picture of it , on the back of a big enough check .
Originally posted by PLUMBER JAY View PostDoes both the hot and cold connect to the top of the hot water heater if so the cold water has a tube that sends the water to the bottom of the tank if this is broken you will have much less hot water available. The cold will come in to the tank and then out the hot side without having a chance to heat up~Blessings~
Nathan
Originally posted by toolaholic View Postread up on dip tube failures ! You may have a stub instead of a full length one, if so it can't pick up the hotter water at the tank bottom!~~
Typically when a dip tub fails, it will start to plug up the aereators and screens on your hot water fixtures.
Unless you have a really old , 20 year heater, the class action lawsuit on diptubes is long gone.
Sometimes it's a bad mixing valve fixture that is crossing over.
See if it continues to be an issue, and if affects the entire house, or just 1 side. Also check the temperature on a 2 handle faucet too. Single handle faucets sometimes will not give pure hot only.
Rick.phoebe it is
