watts valve or water cop Page Title Module
  • watts valve or water cop
    have installed watts wash. machine valves/with water sensor. never installed whole house WATER COP
    any suggestions out there?
    tool, not 100% sure i'm familiar with this. can you give more details. is it similar to the water heater shut off valve if the heater leaks? is there a web link to get some info?
      tool, just looked into it a little more. assuming that the water sensors are placed in an area that is prone to get wet, it should work fine. such as a water heater, washing machine, basement. much less expensive is a water alarm. smilar to a smoke alarm. battery operated and sells for approx. $10. it will alert you to a leak, water and you shut off the water yourself.
      a smoke alarm alerts you, then you call the fire dept. or put it out yourself. same concept.
        thank,s Rick. www.watercop.com
        i have some customers with 2 story beautiful houses.
        money isn,t a problem,water would be ,this looks good.
        i like the wireless sensors.
