48 Gallon water storage plastic drums
  • 48 Gallon water storage plastic drums
    Just picked up 4 new ones with lids $15.00 each . What's Your favorite hose bib set up , Please
    are you trying to stand them vertical or horizontal?
    i prefer a ball valve bibb. the plastic is easily drilled and a bulkhead fitting easily installed if you don't want to use the lids bung fitting.
    Rick.
    • toolaholic
      toolaholic commented
      Editing a comment
      Thanks Rick ,Pretty much what I had in Mind . Barrels will be upright
    i do what rick does - the bulkhead fitting with a ball valve boiler drain. my father in law uses the barrels (his are 55 gallon blue or clear poly with measurements) to catch rainwater for uses around the barn.
    the barrels also make great floats for rafts.
      remove hinge screws DUHH !
