air seal paper for cast iron baseboard
  • air seal paper for cast iron baseboard
    Can I use rosin paper, red or brown, for air seal paper in the cast iron baseboard installation? I am a little worrying the heat may make it shrinking later.
    The baseboard will be installed on the first floor finished rooms. Do you think the foil radiant insulation between the baseboard and wall is necessary? If yes, does the Reflectix double reflective insulation can stand on the heat? There is layer of plastic bubble in it.
    I don't use anything at all. What for?
