changing out cable maxi rooter
  • changing out cable maxi rooter
    I'm adding 100 ft of new cable to 25ft in the machine. Problem is the slot screw head has no slot left from roller wear ! My plan is to braze a small coupling nut on worn head to remove screw . Any ideas welcome. Thanks Tool
    You can cut off the old end and weld on a new end. Call Marvin and tell him what brand and size cable and which ends you need. I change out my female and male ends on my cables as soon as they show a little wear. After cutting the end off, you grind the end of the cable to get a smooth semi-flat surface, then screw the new end in the cable, and then a small weld to secure it in place.
    Here is a decent video
    • toolaholic
      toolaholic commented
      Editing a comment
      great video
    Thanks , I bought 2 sets of weld on ends, with cable from Marvin
      Very helpful link.
      Have you ever used red loctite? If so --how do you like the results?
        Well I got the screw out. Ground in a new slot with grinder,wouldn't budge. Heated with B Tank poured
        cold water on it, bingo came out. I picked up stainless steel 1/4x 20 screws . what color paint do You use every 10 Ft. to mark cable ? I use 3 small bands of white, Yellow,and Red
          i've always used red 10', white 20', blue 30' , yellow 40', green 50'. and repeats.
          stay ontop of the paint before it gets too far gone and it'll be easier to touch up.
          jetter hoses get the colored electrical tape at the same marks. plus a caution stripe at the 2' mark for warning.
          Rick.
            Originally posted by red1234 View Post
            Very helpful link.
            Nope always welded my ends. I run my cables hard in forward and reverse, hate to have them unscrew from the ends.
              Good Job! You got it out..... don't let that screw head get that bad..lol I remember when I had that snake the screw always as f k e d up makes it so you don't change heads. Good job Tool.
              Seattle Drain Service
                  holy triple posting!
