Detecting Gas Leaks
  • Detecting Gas Leaks
    I have the ridgid cd-100 leak detector. I install a lot of 3/4" gas pipe. With that said the gas company pressure tests to 20 psi. Operating pressure is 9-10 psi. County Gas was kind enough to pressurize the lines with gas for me instead of pressured air. So my question is. Do I need to fill the lines with 10 psi of gas and 10 psi of air to get the required 20psi? Also any tips for my leak detector would be appreciated.
    you need 20 psi of air with a tracer gas that the cd-100 can detect. so, any one of these:
    Originally posted by Ridgid
    Methane, Hydrogen, Propane, Ethylene, Ethane, Hexane, Iso-Butane, Benzene, Iso-Butane, Ethanol, Acetaldehyde, Toluene, P-Xylene, Ammonia, Hydrogen Sulfide.
    *Common mixtures that would include or emit more than one of these gases include natural gas, paint thinners, industrial solvents, dry cleaning fluids, and gasoline
    I'd use 2 lb propane containers with an unlit torch head to inject my trace gas.
      So 10 psi NG and 10 psi air would work?
        yes it would.
          i would toss the detector and get a manometer along with a soap bottle. sniffing for a test is a waste of time. soap is cheap and doesn't require you to spend a lot of time at each joint.
          The manometer will tell you very quickly if there is a leak or it's tight.
          Rick.
            I have a TIF leak detector and while it can be useful it has a tendency to create false alarms - the vapors in joint compound for example can trigger the detector and give the impression of a leak when there is actually no leak.
              we have to isolate the new piping from the gas meter . test with air t0 1 1/2 times the working pressure . Usually even if the system is a 1/2 lb system I will pump up my 8 psi gauge to 7lbs. If the gauge drops I break out the soup bubbles .
                True, but pressurized water is much safer than compressed air. Especially at that pressure.
                We use air when testing waste lines over sensitive areas or multi story buildings. 5 psi air is much safer than 4+ Stories of water. That could end up being 16+ psi at the lowest level of the stack.
                Rick.
