Bathtub Drain Cover - how to remove?
  • Bathtub Drain Cover - how to remove?
    First dumb question for the New Year: How do I remove this tub drain cover? I tried pulling up straight, as well as turning it (it turns easily). It just doesn't come off.
    Take the top cap off and remove the screw underneath.
      Pull up tight and turn counter clockwise while holding up
      JERRYMAC
      E-MAILJERRYMAC777@GMAIL.COM
      FIRE SPRINKLER CONTRACTOR,
      SINCE JAN. 1989
        lift up and remove set screw underneath could be this type or any type above
