Can't loosen packing nut for show stem
  • Can't loosen packing nut for show stem
    I have used a plumber' socket wrench, which with all the torque of trying to loosen, has begun to slip off. I have sprayed with PB Blaster, Liquid Wrench and even WD-40, as well as trying heat and tapping with hammer and screwdriver to no avail. It won't budge. Any other suggestions or tools? Thank you
    First thing is to make sure the valve is open fully .... and of course the water is shut off.. they make a heavy duty version of " plumbers sockets " that are less likely to round over on a stubborn valve...
    If your not able to get a pipe wrench on it because it's inset into the wall you could try a metric or standard mechanics deep socket with a pipe wrench to break the bond between the brass male /female threaded connection.... and try not to use a hammer you never know how the fixture is attached to the wall could be just bent nails in which I have seen.
      Forget the packing nut. looks like the packing nut us already out. You need to replace the complete stem.
      Use a normal automotive type of socket. there are times i use an impact wrench to remove stems on widespread faucet so i don't turn the valve body.
      I have a set of gear wrenches that are hollow sockets that will straddle the stem and allow me to use a socket wrench.
      of course turn off the water and open the valve.
      What brand of stem is it?
      Rick.
