Well, it's ME again.
I have attached a picture of a situation in our upstairs bathroom. We had a pedestal sink in there, which began leaking at the connection area. Now, it's a PVC pipe - attempting to capture the threads of a galvanized mating piece. I don't know if those two, differing, properties might be the causative factor - because of the difference. I've gone to Lowe's to pick up new pieces of the PVC portions, and had hoped that it would correct the issue. I found, however, that the PVC 'nut' would NOT seat securely in the threads (I could only get it about halfway on). In addition to that, the nut created no resistance to that elbow being so easily moved in and out of its insertion. I'm nowhere even near being adept at plumbing matters, but I wonder if the nut would have to be tightened all the way down, in order for compression to be achieved. Just as a note, the 'pictured' PVC elbow is the exact same size as the one it replaced.
I hope someone might have a suggestion as to what needs to be done.
Advanced thanks,
Nathan
Advanced thanks,
Nathan
