If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will be required to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I've been following him for years . He's located about 50 miles from me in Dartmouth ( south shore ) . How I found him was I was have trouble with my old Weil McLain boiler and he had a video on the exact same one and how much it sucked working on it ... ( his word's S*** Show ).
He's definitely old school ( no pro press ... metal tool boxes ) and in my opinion the most informative HVAC Youtube channel there is .. and does quality work .
I've watched some of his HVAC tool reviews. Yes it's been useful in helping me decide if I want to buy it - I did not think his videos were outstanding but definitely useful.
I was a little surprised by the sample video when he cut the copper with an angle grinder and reburred and reamed it with a pair of slip joint pliers.
I've not seen that. Did he do a good job? I would never do that for an HVAC refrigerant line - too much risk in getting copper shards into the lineset and causing problems down the road. For plumbing I guess that's ok.
I wouldn't consider it OK, and was taught better than that. When it is possible to prevent contaminating the pipe and you choose not to that is lazy and careless to me. Enough crap gets in there by accident, no need to help.
I agree sloppy work deburring the inside of pipe with his Douglas slip joint pliers , probably made things worst . ( that's what happens when your in a big rush ) . I have work over the last 30 yrs with a Master Plumber who on occasion needs a second set of hands and my carpentry skills ( he works solo like me ) and would be considered a Master Apprentice.
I learned the importance of deburring the inside of copper waterline pipe .. and how not deburring causes flow restriction , turbulance , and creates a vortex about a inch away that down the line leads to leaky pin holes in the line .
