We have a ground level toilet that was installed in the mid-70s when the house was built. It has always been a “slow flusher,” taking 3-4 times longer to flush than other toilets in the house. When I pulled the toilet to replace a leaking wax ring, I saw what may be a factor in the slow flushing. A 4x4x2” offset flange, or at least a portion of one, was used in the installation. Where the angled portion below the flange meets the drain pipe, there is a pronounced ledge that must create significant turbulence in the water flow. My layman’s knowledge of plumbing can’t explain how or why the connection was made the way it was. It doesn’t appear that the lower (vertical) portion of the offset flange is present. A white adhesive seems to encase everything.
Homeowner’s bizarre idea: What if I ground the ledge away to smooth the flow? This would involve grinding cast iron, adhesive(?), and, presumably, some concrete. I would then use marine epoxy putty to reshape and seal the joint. I don’t like the idea of grinding into the drain pipe, but the thought of extracting the flange and integral angle section is daunting. (Note that the white adhesive/filler extends beyond the left side of the flange, partially filling the void that originally provided access to the drain pipe.) Would my solution be anymore cobbled up than the current mess? What would a professional do if this was in his house? Or should I just live with the slow and iffy flush?
Any thoughts or observations are really appreciated. Thanks!
