I noticed a company in the neighborhood doing directional drilling to run fiber optics cables for AT&T.
Can the same sort of service be used to drill a horizontal path say 16" below grade across 40 feet in order to run a 3/4" copper tubing across?
I have old galvanized water supply piping from the 1950s that's living on borrowed time. However, the front yard has a stamped concrete driveway over the existing pipe. To avoid having to cut 40' across the concrete driveway I wonder if I can hire a horizontal drilling service company to bore a horizontal hole under the driveway at a depth of 16" then pull a pipe through?
