I need to install a 3/4" full port ball valve and I would like to know if it matters which direction I install it in.
The valve itself does not have a flow direction indicator, and I don't see how a ball valve direction matters unlike a gate valve.
The valve will be in a vertical position. with the copper coming out from the ground, I would like to have the ball valve's handle point UP while ON, to install the valve as high off the ground as possible.
However I saw this somewhere on the internet: "Ball valves are designed to be opened by rotating the lever handle in a counterclockwise direction, and closing in a clockwise direction. The handle indicates the ball port direction."
If I want the valve to open by turning counterclockwise, then the handle has to point DOWN instead of UP while ON.
How important it is to open by rotating counterclockwise?
