Backflow testing bleed-off valve options
  • Backflow testing bleed-off valve options
    I am getting into backflow testing. I need a needle bleed-off valve for my test kit.
    Is there a reason to buy one manufacturers bleed-off valve over anothers? Is one more durable, easier to use, etc? They run $35-$85 if I buy one.
    OR
    Should I just make one up myself?
    Pics of a generic, midwest and Conbraco bleed off valves are attached.
    Your thoughts are appreciated.
    Isn't this part of the test rig? I currently have the Watts TK-99e and in the past used the TK-99D. I have not needed an additional valve to perform testing.
    I sold the TK-99D a couple years ago.
    I should probably sell the TK-99e as I have not used it in 2 years.
      No, unfortunately they don't. I called the test kit manufacturer.
      Where you live determines the backflow prevention testing standard. USC testing standard requires a needle bleed off valve. Other jurisdictions do not follow the USC standard. So no needle bleed off valve is necessary.
