Gravel in sewer drain
  • Gravel in sewer drain
    The sewage drain in my house got clogged and my entire bathroom floor got flooded. I got a plumber to come and use a power auger to release it. The next day I sent a camera down there and discovered gravel in the pipe about 20-30 feet out. This house is 40-50 years old and I've been the new owner for roughly 6 months. I did not see any cracks in the pipe but may have been covered by debris. How is it possible for gravel to get in the drain?
    Video Link https://drive.google.com/file/d/1VWV...ew?usp=sharing
    I will accept you to viewing it asap.
    Cainsey
    Junior Member
    Most likely the bottom the pipe is rotted out. Hard to tell from the video. Hire out a better camera.
      Just do it ! Start Digging !! Sully
      Clogged pipes can also occur as a result of biofilm formation and slow pipe velocities. I believe this is a result of a mix of factors.
      Drain the system and install a service inlet, which can be a threaded endcap or a tee with a standpipe that is higher than the system's maximum water level. You could then insert a pressurized hose and clean the pipes as needed. I had a similar issue that was resolved by a plumber a few years ago. While you're at it, give the piping a thorough cleaning.
      Bob D.
      Senior Member
