Leak at shower drain
  • Leak at shower drain
ID:	754619 This is the style where the drain line sticks up through a rubber gasket, like a compression washer. The ones I'm familiar with have a plastic piece with a couple of tool slots in it where you can turn it to compress the gasket. This doesn't seem to have that. It's leaking around the outside of the gasket. How do you get this to seal?
    That's a ribbed gasket that normally hammers in and seals on the ribs.
    Try a new ribbed gasket or remove it, clean the rubber and pan, add silicone and the gasket again and let it dry.
    Rick.
