Recommendation; "K-750" or "K-7500"
  • Recommendation; "K-750" or "K-7500"
    I'm looking to buy a drum auger, mostly residential work. Any recommends on which one?
    If you are torn between the 750 and the 7500, I think it would be a good idea for you to check out the new K-6200. It can use 5/8" or 1/2" cable. It has an inner drum like the 7500 but utilizes a direct drive system with an innovative new torque limiting clutch to help prevent cable damage. The catalog number for this unit with 100' of 5/8" intergral wound cable is 93557.
