Hubless connector dimensions
  • Hubless connector dimensions
    Hello,
    Searching for a chart that shows hubless connector inside demensions and what type of pipe is recommened for each end of a paticular connector.
    Thanks, Dennis........
    dennis, you can check with mission rubber. www.missionrubber.com
    they have every type of transition. what size and type of pipe are you joining?
      Rick,
      I do drain cleaning but not plumbing, actually septic and drain. I'm working on my truck stock. I try to put back anything I have to take apart. If a lot is needed then I advise to call a plumber.
      Thanks for the link, Dennis..........
        Originally posted by Dennis/Ohio
        Rick,
        Dennis,
        I would suggest you learn alot more about plumbing based on the following:
        1) I don't know how you can effectivly clean drains if you have no plumbing knowledge.
        2) You respond to stoppages, clean them, and then refer the customer to a plumber to repair the damages? That does not seem cost effective to the customer. Why not hire a plumber in the first place who can do both?
        the dog
