GE Garbage Disposal
  • GE Garbage Disposal
    Guys I need some plumbing help. I have a GE Garbage disposal in my sink and when I cut it on there is a low hum being produced and the blades are not spinning. I have tried to spin the nut that is in the middle of drain however that has not worked can someone please let me know what I can do to fix it.
    If you spun the nut and the blades did not move you may have something jammed in the unit. Dissassemble and flush it out. If the blades spin freely but the motor just hums your start/run capacitor could be burnt.
