sump pump run by water pressure.
  • sump pump run by water pressure.
    Today i was told by my brother about a sump pump that ran off of water for back up purposes. there is a water line connected to the bottom of the pump and with 60 pounds of water pressure going to the pump it starts a turbine that pumps the water out.onthe line comming out you are suppose to go above the check valve. i have never heard of a pump nor seen a pump like this .has any one installed any of these?
    A fishing pole is the best cordless tool!
