How would you de-contaminate water pipes
  • How would you de-contaminate water pipes
    if your house was under water down south? What a mess!
    toolaholic, decontaminaton is best handled with a D 9.
      Well if my insurance was not going to pay enough to replace a flooded house I would at least thouroughly flush all the lines for about an hour then drain them. Then I would shut off the water stops and pump the lines with chlorine and let them sit for a couple of days to kill all bacteria. Then I would flush the lines very thouroughly again and have the water tested. I would also replace all the faucets.
        thank,s plumber, i was thinking, i,d disconnect my side of the meter and pump clorine in and flush. but maybe, after you do a clean job,you,d get re -contaminated by the water district in a few days! What an awful MESS
        I feel blessed and guilty at the same time!
        maybe Bill G is rightabout the D-9
        thank,s TOOL
