Surge of cold water while Showering
  • Surge of cold water while Showering
    I run an apt complex and at the end of one wing I have to suites that are complaining of a surge of cold water while they are showering. These 2 suites are right above each other.
    There shower valves are delta r1300 single lever if that helps? Any ideas what I can do??
    thx to all that give there 0.2$
    surley there has to be someone who might know??
      You may have to change out the cartrdges in the faucets. I have had the problem before with moen type valves.
        My advice costs more than $.02.
        the dog
          ummmmmmmm
          It could be that the balancing spool is getting stuck in one position. Sometimes these can be cleaned up and made to work again if you know how to take the cartridge apart. Otherwise it sounds like a replacement is in need.
          One of the best lessons I learned from my father is when he did nothing to help me. I then learned to help my self.
            There is 2 valves to shut the water off and they are going to the shower.Do you think i`m in for troubles if I take that cartiges out?
            Do I need to shut the turn the water off to the main riser?
              if the screwdriver stops work, that's what they are there for. don't remove anything if the water is still running. use a proper screwdriver so as to not strip the shut off heads.
                well I changed the cartige and so far so good
                  way to go gobby, welcome to plumbing 101
                    Dang just recived a complaint from the resident that they still have the same problem.
                    It`s funny that the resident in the suite below them has the same problem??
                      How old is the building?
                      What type and size of piping serves the showers?
                      How far are the showers from the water heater?
                      Are they individual water heaters for each unit or a central system?
                      When you say a surge of cold water, what temp is the water before the surge and what temp is the water during the surge?
                      Do all of the showers have flow-restricted heads?
                        5 years
                        type L 1/2
                        350 feet with a recirc line
                        they are all running off 3 200 gallon a and o smith
                        I have the tanks set at 120 f.I haven`t measured the temp drop but going off what the residents have told me.
                        yes
                          5 years
                          type L 1/2
                          yes
                            5 years
                            type L 1/2
                            yes
                            There are almost more “what ifs” than anything else in your questions. Assuming the spools on the pressure balancing valves are working you must be getting a blend of hot water and hot water which has lost its temper.
                            If the units in questions are stacked units and they are both feed by the same ½” line you could have an under-designed system. The fact that these units are 350’ away from the heaters means you have 350’ of piping to inspect. If the system is designed to where there is a circulating loop and all of the branches off of that are dead-ends you could be aspirating water which has lost its temper from one of the dead-end branches. In that situation the mixing valve would not react to the change in temperature because the pressure would not change.
                            I think if I were trouble shooting the problem on the job I would be using a thermometer and measuring some temperatures from all the units on that end of the complex. I would also check to see if there were any mixing valves which might be leaking from the cold to the hot. You may also want to consider renting a recording thermometer and watch the branches to those showers over a couple of day period.
                              i have also seen this sort of thing happen when the showers have flow restrictors or are hand held units too. the valve is allowing more water to pass through and the head is so chocked down that the water will end up mixing in the system, instead of coming out of the head. usually a pressure drop on 1 side is the cause.
                              try removing the flow restrictor on the unit that seems to be having the most complaints and see if this helps with the problem. if it's a hand held, remove the hand held and install a regular head instead.
                              once again too many what ifs.
