Rigid Kwik Spin
  • Rigid Kwik Spin
    I've got about 24 1/2 feet of cable down the kitchen drain, and the end of the cable came undone from the winder. Doesn't seem to be a place to attach the spring at the end of the cable. How do I reattach and rewind this thing??
    This cable is not attached to the drum in any way. If you would hand feed about 2 feet of cable back into the drum this will allow the cable to be fed back into the drum with the auto feed of your unit. This cable wrapping around the drum acts as a centrifical clutch if you will, the cable wrapping around the drum and the drum turning will inturn rotate the cable. Hope this helps you out.
