boiler
  • boiler
    where working on a burnham series 2 boiler and the directions call for the water feed on the supply side, but i've seen it on the return side below the ball valve before. Which is the right way or does it matter. Also the circulating pump is best on what side?
    Thank You
    go too heatinghelp.com then go to the wall this is one of the best wet heat site there is jeff
      thanks for the website it was helpful
        I installed a few of them and it dosn't matter if the supply feed is on the main or the return. Infact many people will tell you to feed the boiler on the return side so as not to shock the top of the boiler with cold water. I like to put the circulater on the main and push the water through the system.
