hot water return with no pump
  • hot water return with no pump
    how to circulate hot water without a pump
    on larger homes, apartments, condos, there is a need to keep the hot water circulating so that you don't have to wait for or waste hot water.
    the typical system use a circulating pump and a return line from the remote fixture or fixtures back to the heater. one of the biggest problems with this system is the water is circulating too fast and the copper tubing is wearing out too fast. i have found that pumps are not sized properly and the velocity of the hot water going through the tubing is moving too fast. this is typically happening 24-7. tubing that is not properly reamed or sized will wear out faster than properly sized and reamed tubing. type "m" copper faster than type "l" tubing. "l" faster than "k".
    one practical way to slow the process down is to downsize the pump and put the pump on a timer or aquastat. the problem is that once the tubing has developed its first pinhole leak, the others are just a month away.
    i have found another system that has worked for years without pumps or electricity this is called a "passive hot water loop". it basically works on the principal of specific gravity. hot water being lighter than cold water.
    this system is typically not a retrofit to a typical hot water return, but a design that needs to be built into the original piping installation.
    a hot water return line is run from the remote fixture up to the highest location in the system (attic). then back down to the heater at the bottom of the tank. a check valve, ball valve and hose bibb is installed at this connection too. the system is flushed of all air throught the hose bibb and the water is run until hot. as the water cools down, a natural flow will occur as the water cools it will settle from high loop and travel back to the heater at the lower level.
    the water will move slow enough to cut out the wear from velocity. as long as the system is not shut and drained it will work forever. if you do shut off the system, just bleed the air and run the water till hot.
    this is a brief summary and was condensed so it didn't get too technical
    for all that have a circulating pump, try unplugging it and see if the return line back to the heater stays warm. you might already have a high water passive loop. if so, keep the pump off and you'll save all the wear and tear along with the cost of electricity and replacement pumps.
    if not, try putting the pump on a timer and shut off every 15 minutes and then on every 15 minutes.
    hope this helps.
    very good info rick
    this is the same as the old coal or wood hot water boilers with large cast iron radiators. thats how they got the water to flow to the upper floors .
    thats Wye on todays boilers they use a check valve or a flow valve .this is to stop the gravity flow when you do not want heat .
    now all i have to do is come up with a solar panel to heat my pool water .[and with out a pump if i can help it ]
      ".[and with out a pump if i can help it ]"
      Why, just add a couple PV solar panels and run your pump for free with solar power.
      John Ruskin (1819 - 1900)
        Or you could just move to Phoenix and never worry about heating your pool again....
          hope this helps.
          Rick,
          Here's my take on circ. systems:
          1) If you have a residential property, with (say) two bathrooms, the recirc. system will do more harm than good.
          2) If you have a residential system, and you feel the need to have a recirc. system, use a ":hydro-stat" and a timer. The problem with re-circ. systems is that they wear-out your pipe. Use the hydro-stat to start the pump when the temprature falls low, but control it off a timer that prevents it from activating when you will not need hot water. For this you will need an electrician.
          3) A check valve should always be installed on the cold water feed line which should be connected to the hot water return line.
          Post, if you need more information.
          the dog
            Rick,
            The system you described is interesting, but seems very limited by design. Do you have technical drawing and specs? If so please email them to me. I can see this system working, but I would like to see the engineering. If you have more information, and the forum email system will not support attachments, send me a private message, and I will give you a method of contacting me.
            the dog
