ridgid pipe cutter 258?
  • ridgid pipe cutter 258?
    I would like to know the cut times o this cutter?
    Any size pipe ,
    Any experience would be great
    Thanks
    Rusty
    i don't own one and never used one.
    according to the specs. it can cut sch. 10-40 2.5''- 8'' pipe
    you need a #700 power drive to turn the cutter and pipe.
    as quoted " cutting times varies with pipe schedule and diameter"
    hope this is some help.
    what is your application for this beast
    ps the 258xl is good for 8''-12'' pipe
      Yo Rick Thanks for reply
      I can read too.
      I am looking for any working experience with the cutter
      I install big boilers and I gruve the pipe
      just looking for cutter options hav e you seen the T-Drill pipe cutter I think it is called the super 8
      I am trying to compare the two
        pipe cutter
        Any size pipe ,
        Thanks
        Rusty
        Probably too late for this post, but you can't beat that cutter, takes less than a minute to cut most pipe if you have a sharp wheel. I use it for Vic. type connections. Like the other post said, you need a 700 power drive. If you decide to buy it you need two pipe rollers. Lots of luck.
        "If you don't have the time to do it right, where will you get the time to do it over?'
