A O smith hot water tank.
This topic is closed.
  • A O smith hot water tank.
    I have a 200 gallon and I loose tempature on it.The damper always stays open??
    I have changed the board and motor on it and then it will work for a while.I come back and check it 4 hours later and the damper is open and i`m loosing temp.
    I raise the temp on the thrmastate that doest start it up I them wiggle the damper then it starts up???
