Attaching PVC to cast iron?
    dog wrote
    As recently as three months ago I was dinged by an inspector in orange county for using a 2" no-hub band on an ABS to CI transition.
    Isn't cast iron and plastic the same outside diameter. The transition bands we use say ci pl to k or ci pl to ci pl.
      The bands I use are usually made by Mission, Anaco, or elsewhere and listed as cast iron no-hub couplings. Keep in mind that I work in large scale commercial construction. I order no hub couplings by the hundreds, if not thousands. Bands rated for "cast iron X plastic" are more expensive. If I was running a repair truck, it would make sense to stock the more versatile couplings, but in my situation, the dollars add up for more expensive couplings, and are ordered per need.
      the dog
