Saw Blades for Angle Grinders
  • Saw Blades for Angle Grinders
    Are saw blades for cutting wood made for angle grinders?
    I have a need to fit a small saw into an opening to cut out rotted wood. I have a 4 1/2" angle grinder that will fit between the floor and the bottom of the cabinet but am having problems finding a saw blade for wood that will work with an angle grinder.
    any suggestions are most welcome.
    Re: Saw Blades for Angle Grinders
    Here is one option
      Sorry to answer your question with another one but wouldn't the disc that are made for cutting metal also cut wood? Cutoff Wheels For Metal
        a metal cutoff wheel would end up burning through the wood rather than actually cutting the wood.
        thanks for the link.
          Metal cutting blades will burn the wood and cause a lot of smoke and possibly a small fire in the process. I've never seen any actual saw blades for angle grinders. Seems continuos rim blades is the way to go with them. If there were saw blades I'm not sure I'd go anywhere near that. At 10,000 rpm you better get a good grip on the tool.
            From your description, a sawzall sounds like it would work.
              Here's another option.
              Cheers! - Jim
                The kits you can buy for this have safety guards, but still be very careful. I've tried using one and they can easily kick back on you. It's pretty dangerous to have the tool flying with that blade spinning.
                  Franklie,
                  Before you invest in saw blades for angle grinders (I agree, a 13,000 rpm saw blade spinning on a 4.5 inch angle grinder with the trigger on seems a tad, uh, nuts), have you thought about a Dremel. I use my Dremel with a Rotozip zip bit for wood to cut out rotted wood on windows and windowsills all the time. You can use it like a dentist's drill and route out a small area or a big area or cut in a relatively straight line. Dremel even has a router attachment that you can screw on the front end and use it to regulate the depth of your cut. Also, if the Rotozip bits don't do it for you, Dremel does have straight cutting small router bits that can be used with the tool. Just an idea.
                  Hope it helps.
                  Jim Don
                    Just a thought, what about a biscuit jointer or a jamb saw like floor tile installers use to cut door jambs/facings off with???
                    Regards,
                      try one of these http://www.feinus.com/
                        Sears makes a two blade counter rotating saw and zip mate makes an attachment for their tool that will cut wood.
                        Willy
                          Try this Blade it fits any almost any angle grinderhttp://www.kwiktoolusa.com/c7badblade.html
                            Try this Blade it comes in sizes 4.5" to 14" and will cut almost anything
                            Willy
                              Check out this site: http://israelexporter.com/camel-grinding-wheels
                              they may have what you're looking for.
