installing wire mesh
  • installing wire mesh
    I know the wire mesh sheets have to overlap 6 inches. my question is for tying them together. do you have to use wire or can you use plastic zip ties? also does ever square that's overlapped get tied at both ends?
    thanks,
    Re: installing wire mesh
    If you are speaking of the wire reinforcement for concrete I just use the wire edges and ends to 'tie' the pieces together, no need for zip ties, loop one around every few feet. All you are doing is linking the runs tight enough so that when you hook it with the rake to pull it up into the middle of the pour it stays together
      agreed, and to add, you tie it together so you dont trip on it as much. You can use whatever you want to tie it together, zip ties, tie wire, wire ties, etc.
        Zip ties work well for the most part and are easy to find.
