Mystery red Stain in Bath
  • Mystery red Stain in Bath
    Hi all,
    I had some sheetrock work done at my house on a bathroom about 1 year ago. Most of the corners have developed a red stain at the edge. At first I thought it was some kind of mold, this does not seem to be the case. What I believe is happening, is the sheetrock corner bead is rusting and bleeding through the paint. Is this a common problem?
    Thanks Bob
    Re: Mystery red Stain in Bath
    it could be that and the fasters as well most builder wont use stainless or galv, to corners should have been plastic but you can put a few coats of kilz on there and repaint, that might work though i am not sure for how long
    9/11/01, never forget.
      Nice tip, I will do that.
      I am redoing my other bath and this time I will try my hand doing the sheet rock. I did not know they had plastic corner bead, I will use that. you would think the pro I hired would have known that. You know, I might just call that guy back.
      Thanks Bob
