garage under house
  • garage under house
    Are there any issues to worry about with having a garage under the house (i.e. in lowest level of house), in a newer home?
    I can think of two: water drainage if the driveway slopes down to the garage, and cold floor in rooms above garage in case of poor insulation on the roof of garage.
    Any others?
    thanks
    D
    Re: garage under house
    Check with the local town/county office for any code requirements for attached garages. Be specific and ask about living quarters above a garage. The garage must be sealed completely so that any exhaust gasses from the automobiles from permeating into the living quarters.
      The Dry wall (wall coverings) will probly need to fire rated, for how long you will need to check with your local codes.
        Aside from code requirements there may be a significant difference in insurance premiums.
          Just finishing up a garage that's under our living space.
          I ended up putting R-30 in the floor joists, doubling 5/8 fire rated sheetrock & sandwiching this stuff http://www.greengluecompany.com/ in between the two layers of sheetrock, for it's sound damping qualities.
          With the insulation, doubled 5/8 sheetrock & the Green Glue for sound damping, we don't hear squat in the living areas from the garage (even with compressor running) & vice versa.
          I also installed an automatic fire sprinkler system in the garage.
          Knowing cars sometimes spontaneously combust, even hours after you've parked them, that just didn't sit well with me knowing I was sleeping directly above.
          Way overkill as far as code compliance (could've gone with the fire rated sheetrock or the sprinkler system & either would've been satisfactory), but I sure do sleep better at night.
          Last thing I did was hang an air scrubber with Charcoal Filter for the CO-2 & install a hard wired ~ battery back up CO-2 / Smoke Detector combo.
          End result, Building Inspector was tickled pink with how I did the garage & our Home Owners Insurance has gone down 10% because of the automatic fire sprinkler system.
