Weight of snow pushing on wall
  • Weight of snow pushing on wall
    I'm starting to get kind of concerned with the amount of snow sliding off the roof and pushing on my back wall. I'm wondering how mush weight is pushing the wall. I have not noticed any cracking in the sheet rock or any bowing or anything like that.
    The wall is 50' long and built with 2X4's 12" o/c. Including the two outside walls it has 5 adjoining walls that run perpendicular with the longest stretch of no adjoining perpendicular wall being 14'.
    I'm not concerned with the front wall that is 50' long with no adjoining walls other then the outside ones as this is a 16" thick cord wood wall that even a bulldozer would have a hard time pushing over.
    Re: Weight of snow pushing on wall
    Actual snow pushing on wall is about 5'.
      Its good insulation.....
      Usually in a situation like yours, the warmth from the walls will melt anything touching it, so there could actually be a gap between your wall and the mound of snow and you can't see this.
      But for your own piece of mind, then remove the snow....
      How much of a push can your walls withstand, this all depends on how it was built....
      I've seen snow, go all the way up to the roofs, really the only bad thing I have seen go wrong, was some water getting in through the windows.
        is it 2x4or 2x6
        i would get it off the wall before the water starts going into the wall like garager said
          You could go through a lot of math to figure out how much pressure is being put on the wall. First you have to figure out how much of the snow it takes to make a gallon of water. Chances are it's a LOT of snow! Then, using the weight of 1 gallon of water, which is generally given as 8.33lb. There's a function that'll give the amount of pressure.
          Generally, the weight of the snow isn't the problem, however. The problem is the melt/freeze cycle of the snow that causes the siding to open and allow more water in. This is especially bad around windows. Garager's right.
          BTW, that's a LOT of snow! Y'all want some of our ice to go with it? And...no fair gloating about the cool shop!
            Thanks for the advise, even though I figured it would involve the S word.
            Yes, SHOVELING. I'VE HAD ENOUGH OF THIS WINTER! What ever happened to global warming?
            Thanks again for the advise. I was so concerned about the weight of the snow, I lost sight of the fact that that snow will soon turn to water.
            Yes it is 2"X4's 12" o/c. I got a wicked good deal on 2X4's.
