Rough opening for prehung doors
  • Rough opening for prehung doors
    Is there a general rule of thumb on a rough opening for a prehung door for all doors?
    Re: Rough opening for prehung doors
    Your question is a little vague. If you're asking about how much wider the rough framing should be than a pre-hung jamb set, most guys will add a quarter inch to each side for shims, so the answer would be 1/2 inch wider.
    Personally, I like to take an extra minute during framing to make the hinge side studs perfectly plumb and square, then I can nail the jamb directly onto the framing. This way I only need the framing a quarter inch wider than the jamb set.
      Thank you for your answer. What I am trying to say is, for example for a 36" door is there a perfered rough opening and so on for a 32" or a 6' french, all prehung.
        check this out
        http://www.thermatru.com/TechManual.aspx
          Originally posted by charliesam53 View Post
          for example, for a 36" door is there a perfered rough opening and so on for a 32" or a 6' french, all prehung.
          Gotcha. Some people will say you can just add 2 inches to the door size and you'll be o.k.
          Unfortunately, if you order three 36" doors from three different manufacturers, they'll all be a different width when you actually put your tape on them, so beware.
          But if you don't have your doors on site when you're framing, you have no choice but to guesstimate.
          Fun fact:
          The phrase "rule of thumb" comes from a British judge in the 1700's that said a man may legally beat his wife, provided that he used a stick no thicker than his thumb.
            ROT for doors when you don't have the suppliers' info:
            Door width + 2 1/2", Door height + 3". For the height, remember you have to have room for the threshold, which can greatly vary in thickness.
            Go
              Interior Door is 36" jambs are 3/4" per side, I like 3/8" for shimming each side, 6' 8" high, you have to add 3/4" for the jamb 3/8 for shimming and clearnace to finished floor, usually 1".
                I use 2" over on the width, 3" over on the height.
                  Width + 2", Height + 3" is industry std.
                    Thank you for all your help.
                      Is that it, no more replies.....
                        2" W , 2-1/2" H
