finishing garage ceiling question
  • finishing garage ceiling question
    ok so in the next month I should have time to get back to my garage building. for the ceiling what is the recommended /prefered way? do you staple the vapor barrior to the rafters and then install the 1x3 or 1x4 strapping? also is it reommended every 12" or 16" for the strapping? also for insulation is better to put batts in between the rafters and then blow more on top or just blow the hole thing in?
    thanks,
    Jeff
