Replacing the roof deck - what material?
    Re: Replacing the roof deck - what material?
    The same advice for buying tools probably applies, buy the best you can afford. If you gotta replace the roof and you are strapped for cash double up the osb (cringing as I suggest this) BUT if you can afford it definately rip and replace with 3/4" T&G, 2 layers of #15 felt with a generous overlap and a high quality (30 year) composite shingle. Now that is a roof you can sleep restfully underneath.
      30lb felt, ice and water up the roof so your past the inside of your exterior wall by 6' (in my area), and I will never use less then 35yr Architectural Shingles. I'd rather be at the 50yr warranty. I personally will not do a roof under 35yr warranty shingles, not in MN. I do wholeheartedly prefer Architectural Shingles over 3 tab shingles and 100% of my jobs now are with Architectural Shingles....
        Garager
        I understand going for 35 yr shingles but why architectural shingles? I thought that was just an 'look' and had no functional value.
        Andrew
          Originally posted by athuswal View Post
          Garager
          Andrew
          No functional value, I think you need to pick one up someday and take a good look at how they are made. Also, they go up real nicely....
