Least Maintenance
  • Least Maintenance
    What are some building tips that would make a residential structure need the least maintenance?
    Roofing?
    Siding? (More choices than brick)
    Crawlspace or not?
    OSB vs. Plywood?
    Windows?
    Mechanicals?
    And anything else?...
    Re: Least Maintenance
    1. Lighter colored Shingles, last longer
    2. CertainTEED concrete board siding
    3. Not sure with Crawl space I say yes from a plumbing standpoint
    4. Plywood, it is just better
    5. Hydro Air and AC
    6. Concrete Pavers for driveway, Last longer than Asphalt
      Excuse the ignorance, but what's Hydro Air systems?
      What about metal roofing?
      Interior flooring?
      Interior wall finish?
      Just thinking about building rental property so I would like it to be the least maintenance possible without having to make it look like a prison.
        This is one that could be added on forever, good thread...
        Roofing.............. Steel
        Siding................ Steel, cementacious (sp?) material
        Windows............ Steel or Vinyl clad w/low E gas
        Wood, over plywood and OSB. But certain applications can call for plywood over wood.
        Fascia and soffits............ Steel
        Doors................. Steel and Fiberglass
        Flooring.............. Tiles and Cement
        Counter tops........ Stone
        Insulation............ Spray foam
        Basement over crawl space, or slab house
        Basement wall........ Cinder blocks, and the grounds (drain tiles and back fill)must be done right and water membrane on wall...
        House venting.... Soffits to peak, not gable
        Lots of windows on South side, very little windows on the north side, just enough for cross winds when windows are open...
        Plaster on interior walls
        Real wood for interior trim....... Looks so much nicer and no Maint. unless your tired of looking at it and wanna change to a color
        All appliances, energy star ratings
        One story house, w/a basement
        Light fixtures and receptacles and switches, you get what you pay for, thats common sense right there.
        Plumbing, plumbers can jump in, but I'm sure its all plastic and PVC.
        I'll add more later...
          Steel siding and roofing, has many appearances for eye candy now a days. Down south, you'd maybe go with Terracotta for roofs....
            Interior flooring?
            Hydro Air is a small like 3 section boiler that heats the water in a heat exchanger then goes into a traditional cental HVAC system
              Interior flooring?
              A hydronic coil with a blower...some southern states use them right off a water heater.
                Composite deck
                Brick patio or cement, is better then a deck.
                2' overhang w/roofs
                  Plaster on interior walls? A little more info please.
                  Is gable venting seen as inefficient/unnecessary?
                  What about steel studs?
                  Stone countertops? Would there be a manmade equivalent that would come close in durability with less expense?
                    I say copper for water and PVC for waste if you want maintenance free althoug make sure your water is optimal (i.e. pH and Chlorine content) for copper other wise..... ugh PEX. By no means do NOT use CPVC
                      Thanks Wrench and Duck!
                      I asked about Hydro Air a long time ago with little info given. Maybe I didn't know the correct term.
                      Are there any brands or websites? I went to a tradeshow where a company called FHP-Florida Heat Pump(I think?) made something to this effect. It seems theirs was a system where the heat pump and water heater worked together somehow for better efficiency. Trying to learn HVAC principles.
                        What kind of info you looking for? Its plaster board and then Plaster coatings, its a fantastic smooth "hard" finish. Notice the key word...
                        Soffit to peak venting will release more hot air out of the attics then the gable ends can do. It works like a chimney...
                        I didn't think about that, sure. They would work great in interior walls, but exterior walls, you would want at least 5 1/2 in thickness for better insulation. I'm not sure if they make them at 5 1/2 wide. If they do, go for it, you'll have the straightest walls in town.
                        Man made, that'll work, cement will last a long time.
                        This is a great thread, thanks for starting it... Other contractors will chime in, but each area in the states may need different materials, because of our climates...
                          Geothermal heating if you had the area........
                            OHHHHHHHHHHHHHH!!! Good Idea!!!!!
                              Geothermal!?
                              Don't get me started on investment vs. payback. Remember too, possible rental property.
                              Plumbing. Plenty of cleanouts. Least amount of turns in the DWV of course. Class 5 flushing or maybe Pressure assisted. Vents straight out the roof like in the days of old so no turns for the cable man.
                              PEX or TYPE L or K copper underground? $$$
