good tip or not
  • good tip or not
    Window sill is easy rotten. This site recommends a tip that cover the sill with a sheet of aluminum and paint it to match the wood.
    http://www.hometips.com/content/frames_ef.html
    It is a good idea or not?
    thanks,
    Re: good tip or not
    The tip does not mention that the wood is rotten, it is a good plan if you want to cover wood that is in good shape except for the paint it part. I would cap it with a coloured aluminum that matched what I was capping. If the wood is rotten it needs to be replaced then capped
      Re: good tip or not
      Once again, this is the stuff for rotted wood.....
      http://www.advancedrepair.com/archit...artssystem.htm
