Question About Sill on Slab
  • Question About Sill on Slab
    I just finished laying the sill down for the exterior walls for a shop on a concrete slab. Now I was wondering, do i need to lay a sill down for interior walls or can I just get away with PT bottom plate?
    Thanks, Fuller
    Re: Question About Sill on Slab
    For the price of undersill, Just put it on.
    But I think the NBC says you have to put undersill. But for PT im not sure. My books are at work. will check tomorow.
      Alright, thanks. I was going to anyway but I was wondering if i really needed it.
        Yeah as per the Canadian National Building Code
        9.23.2.3
        1) Wood framing members that are not PT with a wood preservative and that are supported on concrete in contact with the ground or fill shall be seperated from the concrete by not less than 0.05mm polyethylene film or type s rool roofing.
        So i guess the awnser is no ... But when I do a basement i use PT for my plate and i put a sill gasket...
        But the NBC is just bare minimum
          Thanks. Yeah thats what I was going to do, gasket, PT sill, then my wall.
