composite siding?
  • composite siding?
    I'd like to use a composite material for the siding of my shed. Something I can use in a board and batton configuration.. any suggestions? I see a lot of composite decking materials, but not siding, is there a reason for that?
    --Jeff
    Re: composite siding?
    For siding, I don't think there is an alternative that is as cost effective and low maintenance as vinyl siding, though I'm not sure if it's available in a form that will create your desired look. Composite decking itself isn't all that it's cracked up to be according to an online Q/A I found. It is a bit dated though so maybe the manufacture quality has improved since then.
    http://www.askthebuilder.com/551_Com..._Decking.shtml
      If longevity is what you're after then I would consider something like Hardiplank...
      I don't think you can do board and batten with it but they do offer a vertical siding (see link above)
      Cheers! - Jim
        --Jeff
        T1-11
        http://www.protek-usa.com/PDF_Files/...0Solutions.pdf
        Or SmartSide
        http://www.lpcorp.com/default.aspx
