chemical to remove old paint
  • chemical to remove old paint
    i was told there are some chemical can be used to remove old paint. anybody use them before?
    thanks,
    Re: chemical to remove old paint
    Here's a link I found that talks about paint removal. I've never used a chemical paint remover before since I prefer sanding, I don't like keeping lots of toxic chemicals at home.
    http://www.doityourself.com/stry/h2removepaint
      I'm pretty sure that Home Depot or Lowe's both carry at least 1/2 dozen different chemical products to strip paint. A heat gun works pretty good in some situations also.
      Gels cling to vertical surfaces better and don't dry out as quickly. It can get pretty expensive though.
        Ive used a chemical called circa 1850 before. It works pretty good. It's not too harsh smelling either. I bought it at Canadian tire but you might be able to get it at the home depot in the U.S.
        Good luck with your project
          The best (safest) method will be determined partially by the paint itself. If it contains or could potentially contain lead, then you need to think carefully about how you remove it. Sanding creates much airborne particulate matter that will contain lead particles sized just right for you to inhale and stick in your lungs, and it creates a potential hazard for anyone in the area too as well as wherever that dust settles out at.
          Chemical paint removers have their own set of problems and advantages in some situations. Just be sure and review the label and also go to their web site and find the MSDS sheet which they MUST supply to you by State and Federal law(EPA regs as well as OSHA).
          A heat gun can also work but again with lead paint the fumes from a heat gun make this method a no-no w/o controlling the fumes even when working outside on the exterior of a building.
          http://www.cpwr.com/pdfs/pubs/hazard_alerts/kflead.pdf
            This paint remover worked for me.
            Woodworking Hardware
              I think this is enough .....
              I do agree with you. Those are the most effective way
              Electric adjustable bed mattress reviews - Asjustable beds prices air and Sleep Comfor in the UK
