Which drywall manufacturers are safe?
  • Which drywall manufacturers are safe?
    I want names. We've heard about so-called "chinese drywall", but I never heard actual names of manufacturers that were under suspicion.
    Now it looks like the problem may not just be limited to drywall imported from China. I just saw on the news that a family is suing "Atlanta Pacific" for a similar effect,
    http://money.cnn.com/2009/06/05/pf/s...n=money_latest
    I read the article, and it sounds ominous.
    So, exactly which US-based drywall manufacturers *do not* use this synthetic gypsum that apparently comes from the scrubbing of coal smokestacks? If it turns out the Atlanta Pacific drywall really is tainted too, then where does it end? www.gypsum.org put out a flyer saying that it's common for its member companies, which includes Atlanta Pacific, to use synthetic gypsum. Is there a "safe source" for drywall that doesn't use synthetic gypsum in their drywall formulation? If there exist domestic manufacturers who don't use synthetic gypsum, I want some names. I'm ready to switch suppliers *now*. I'll be happy if domestic manufacturers prove themselves innocent, but meanwhile I would prefer to avoid any possible problems.
    Please advise.
    Re: Which drywall manufacturers are safe?
    Anyone?
      I'm also interested in finding more about this as well. I'm still budgeting for finishing my basement, and I want to know what quality drywall will cost.
        I'm sure many brands are safe but I like Sheetrock the best, plus you can get it at Home Depot.
          Drywall is made from gypsum, which is calcium sulphate CaSO4.
          The bad drywall, apparently, is contaminated with calcium sulphite CaSO3. Sulphur contained in coal can burn down to SO3 or SO2, depending on the oxygen concentration. SO3 makes sulphates, SO2 makes sulphites.
          Wikipedia article about calcium sulphite tells it straight:
          Like other metal sulfites, calcium sulfite reacts with acids to produce the respective salt, sulfur dioxide gas and water. For this reason, CaSO3 is not a desirable compound in drywall - when humid, it releases sulfur dioxide as moisture and carbon dioxide are absorbed and mix to form carbonic acids.
            I belive Knauff was one of the big brands that were importing from China.
              I guess that to check if the drywall contains much sulphite, peel the cardboard off a piece, and pour some plain carbonated water on the gypsum. If it gives much of sulphuric odor, it's no good.
                Link to Wikipedia article
                http://en.wikipedia.org/wiki/Sheetrock
